Author Topic: synchronized lyrics in MusicBee API  (Read 6003 times)
slimmeke
Hi
Does MusicBee API support synchronized lyrics?
And if it support it how does it work?
Guys best Music Player in the world.
Keep up the great work.
only supported for reading and writing as a tag. You can make the lyrics scroll by controlling the play position
slimmeke
Is there a possibility for checking if the lyrics is synchronized or not?
