Author Topic: Please return the opportunity to listen to the song separately.  (Read 2708 times)
WladislawW
After the appearance of a new type of album, lost the ability to choose individual songs. Now just listen to the whole album?
Please return the opportunity to listen to the song separately.  :-[
i'm not sure i understand exactly what you mean, but i have made a change to how tracks are selected for playback so playback of selected tracks in the expanded view is consistent with other layouts. See:
http://getmusicbee.com/forum/index.php?topic=12609.30
If thats not what you mean, can you post a screenshot and more detail about what you mean
WladislawW
How to choose a ONE song on the new menu album? Played the entire list.
Here's how to post a screenshot if you need to: http://musicbee.wikia.com/wiki/Screenshots
But it sounds like Steven has fixed it.  You just need to wait for the next patch, which he will probably link in this thread.
you can change your Now Playing preferences to play the selected song only, otherwise you will need to give an example and screenshot of how it used to work and how it works now
WladislawW
Thanks, option. Found it. The next time the program update correctly.
