Author Topic: Folder sort order on computer node + find border name  (Read 2235 times)
Diedrict
hello,
thank you for previous fixings.
sort order of --- computer node - > folders list view ->
"folder_name added_text"
"folder_name"
sort order of --- file explorer -> left side folders list view
"folder_name"
remove quotes
folder_name is identical in all
added_text is identical in all
mb swaps the two folders, please make same as file explorer
question. what is find input border name in skin file, i need to add to skin file as now transparent
greetings
What version are you using?  I think folder sorting was fixed, but maybe this is a different case.
A screenshot of what element you want to change would be helpful.
Diedrict
Diedrict
transparent fixed - thank you.
sort order still exist
greetings
