Author Topic: Support for Droid?  (Read 5991 times)
Gattaca
Does MB support the Motorola Droid? If it is supposed to, then it's not detecting it  :'(
in the devices preferences, tick 'detect MTP devices'
if it still doesnt work, could you try this version as it fixes handling for devices that dont support returning the storage capacity
http://www.mediafire.com/?ywljmomwmqd
Gattaca
I did select the MTP device thing, but it doesn't work. And so I tried downloading the version you gave me, but it won't open. It says I need to install the full version.
its a patch version - just copy the unzipped MusicBee.exe file to where MB is installed.
If it still doesnt detect the device i can give you a debug version to see where its going wrong. However I know a number of people using MB with droids so it should be able to work
Gattaca
Thanks! I got it to work now. I think I just redownloaded the latest beta and installed that.
