Author Topic: Expandable View in the Artwork layout  (Read 111968 times)
Yes, the bug's finally fixed. Also thanks for supporting the mouse scroll wheel for navigating on the album list panel! It's so much easier.
Alumni
Can we have the option to disable the sideways scroll-wheel in the expanded menu?
Personally I would rather be able to keep scrolling up and down without losing focus of the main panel.
Last Edit: December 31, 2014, 04:53:48 AM by Alumni
mikebo
Maybe it would suffice if the horizontal scrolling was slightly delayed, so that it wouldn't interrupt vertical scrolling.
i changed it so the horizontal mousewheel only activates when the mouse is near the horizontal scroll buttons
mikebo
I think that will make it much less discoverable, because nobody points their mouse on the arrows to scroll the wheel, as the scroll wheel is expected to work anywhere on the scrolled canvas.
Even with default font, displayed text under artwork gets cut off if you move the slider to the leftmost.
Really? As I said I'm using default font (Segoe UI, 9pt).
ok, i see its actually one of the settings that causes the calculation to be slightly wrong
