Author Topic: Create a playlist with all Track having a VBR  (Read 2771 times)
Arathon
As per title how can i create a playlist with all Track having a VBR? In the bitrate field i can't specify VBR or CBR.
Until there's another solution, you could try "bitrate is not any of..." 128, 192, 256, etc.  Definitely a kludge, but it should work for the vast majority.
Create a virtual tag which just contains <bitrate>.
This will let you match on the bitrate as a string, so you can create an auto-playlist (or filter) with the rule:
<bitratestring> contains "VBR"
You'll need to tweak it if you have "Show Encoding Quality in place of Bitrate" enabled, but I think including any bitrate that includes a "V" would work.
Huh, I thought you couldn't use Bitrate in Virtual Tags, but I see now that you can.  Great!
Arathon
Perfect i'll try it (now i'm away from my pc  :( ) Thank for the sharing btw.
