Author Topic: Small issue...  (Read 1451 times)
stylostar
Back to using MB after a while away.
I quite like the new track popup but it imposes itself in the lower middle of the screen just where I am trying to do something in a spreadsheet or whatever. Any way to move it? It is now turned off.
In theory, you can drag it wherever you would like and it will stay there.  I've found in practice that it often resets itself.  More documentation on that issue might be helpful, if you run into it.
stylostar
I should have tried the obvious in dragging it out of the middle of the picture!
It is working for now. Thanks.
