Author Topic: HELP! New User :(  (Read 1500 times)
BelieveInHipHop
So, having used Macbooks and ITunes for many years, I have recently switched to Windows 8.1 and decided to go with MusicBee as my music library/player. I have a problem though, burning CD's via WAV is working fine (even though I keep having to type in so much information myself), but I have two mixtapes I downloaded off the internet that are in MP3 format, and I have NO IDEA where I am supposed to move them :/ It's been years (around 9) since I used a Windows PC and I'm not very tech savvy anyway...but can someone walk me through what I need to do to get these two albums in my library?
Welcome to the forum!
Do you mean you are ripping CDs to WAV?  You may find FLAC a more functional format.  It is also lossless (CD quality audio), but with smaller file size and better metadata support.  Also, if you can show us what you're doing (http://musicbee.wikia.com/wiki/Screenshots), we may be able to save you work on entering info.  MusicBee has pretty good auto-tagging features.
MP3 files can be dragged from Windows Explorer to MusicBee, or you can scan them in using the Rescan/Add Files popup.  See this page for more info: http://musicbee.wikia.com/wiki/Importing
