Author Topic: Can ratings be synced FROM an android device?  (Read 2797 times)
atjasc
I use PlayerPro on an android device and it registers the ratings that I made on the computer with MusicBee, but I can't figure out how to rate the song on the device and have it update on the computer. Is the sync only one way? Is there any way to have ratings update from the most recent source (i.e. the most current rating from either the device or computer)?
Not supported. There's a wishlist item about such feature.
lnminente
I tested PlayerPro but any setting i tried the song files were not updated, so i suppose playerpro is storing these ratings in its internal library which can be exported to the pc in itunes or songbird xml format
