Author Topic: Auto shutdown problem?  (Read 2873 times)
dylstew
I've been using auto shutdown lately, and sometimes it doesn't shutdown and sometimes it does.
When it doesn't, I get this message about musicbee saving a file and how if I let it shutdown now that that will be lost.
What does that mean, and how do I avoid the message?
Perhaps you edited a tag and didn't save it? A screenshot would be helpful.
dylstew
dylstew
Could I please get a bit of help on this?
last time I closed all other applications and restarted Musicbee.
After I turned on autoshutdown. I did this just to be sure
yet when the playlist ended , it STILL somehow showed this message and didn't turn off, yet sometimes it doesn't.
you probably have some process still running such as updates from the Tag Tools plugin or perhaps you imported new tracks and MB is doing a volume analysis for the new files if you have that option enabled
