Author Topic: capitalize genre  (Read 5077 times)
TASMANI
how can i capitalize only genre field?
and second question if we have double genre in one track how can delete it easily?
for example i make some things wrong and i saw to a track that has that genre
Alternative Pop Rock; Alternative Rock; Alternative Indie Rock; American; American; Live; Pop Rock
American is twice
and a third question how can we make a date in this form 01/01/2014 to year field to show 2014 only the year i mean
Last Edit: April 02, 2014, 09:32:28 PM by TASMANI
TASMANI
this plugin solve me one of the three problems i had and specific the probleg with capitalize but whata bout the other two?
American is twice
Use Tools> Tagging Tools> Search & Replace with the following settings:
If there are multiple duplicate entries, you need to apply it multiple times until there's no match.
Add Year(yyyy) field from 'Other fields' to the main panel.
@TASMANI
Try latest version of plugin:
http://musicbee.wikia.com/wiki/Additional_Tagging_and_Reporting_Tools
Advanced Search & Replace command, 'Remove duplicated entries from <Tag 1>' preset.
TASMANI
ok with the years problem
about the duplicates genres ... redwing solution didn't work it says to me NO MATCHES FOUND
boroda74 i found the  Remove duplicated entries from <Tag 1>  preset i use it but it didn't make any changes
but itried to some tracks and i figure how it works..but something is wrong for example
Alternative Rock; Hard Rock; Heavy Metal; Metal; Pop Rock; Rock; Speed Metal
the preset change it to
that means speed metal because of metal duplicate erase the metal from speed but these are not duplicates genres
Last Edit: April 04, 2014, 10:18:13 PM by TASMANI
On further tests, I can confirm the regex I posted before is not working for some cases. If I can improve it, I will post it (But, it's not easy to make regex work for multi-value fields with the tool). Otherwise, wait for boroda74's fixing the preset.
Search for:
([\s\S]*)\1
Replace with:
$1
will work for genres in multiple words as well. But, it only works when the track has multiple genres. So it works for and can fix "Hard Rock; Hard Rock; Pop; Pop", but doesn't work for "Pop; Pop".
TASMANI
as i can see redwing solution worked just perfect in the tracks that i have notice the duplicates entries..
now i will try the preset too
thanks both of you for helping me and everyone in this foroum
