Author Topic: Show CD in Library Tree  (Read 3126 times)
V4lve
Hi.
Whilst MusicBee is quite capable of playing, tagging and ripping CDs the interface is pretty sparse, almost obscure.  Would it be possible to add a item to the library tree for CD to give better access to these functions?
Ta
you can access the CD from the computer section - was it that you didnt realise that or is it just a case of adding some more right-click options?
V4lve
Aha.  I don't use the computer section function so turned it off.  Would it be possible to show show the CD in the main library section instead if the computer section is turned off?
