Author Topic: No stop button on right sidebar?  (Read 4847 times)
Jerm56
No matter what I do I can't seem to get the stop button to appear in player controls when in left or right sidebar. The stop button is only visible if my player controls are on the top or bottom pane.
I can still stop tracks don't get me wrong, but I have to click the settings button or right click. It's bothering me because I've recently just reinstalled musicbee, and I remember having a stop button on the player controls panel while on the right side before.
Is there anything I'm missing?
Hold down Shift while clicking the play/pause button.
Jerm56
Thanks! Now I feel like an idiot, this will do the trick though. However I'm still wondering if there are any settings I could change to always show the stop button? I remember not too long ago (maybe it was a slightly older version?) having a stop button alongside these. Can it be done or has an update killed that?
It was changed to be consistent with the Compact and Mini Players.  You could also use the hotkey for stop, which I believe is Ctrl+S by default.
Analien
I still think that rightclicking the play/pause-button should act as a stop.
You can also add a Stop button to the popup controls that appear when you hover over the MusicBee button on the Windows 7/8 task bar.
