Author Topic: Is it possible to do a Custom Volume Slider?  (Read 6796 times)
Kusaywa
Can you take the default Volume Slider and Customize it like you can with the Play, Next, Buttons?
Or at least place the Volume Slider where you want?
THANKS
Currently you can only use either volume slider with default TM player (e.g. Artist Picture view) or just volume up and down buttons without a slider (e.g. Vertical Mini view).
