It's working much better without crashing at all. Before this, some strict steps were required for operating it to avoid a sudden crash. But I have two wishes, both of which were possible before:
- Allow to place MB on desktop mode upon clicking on the icon from taskbar. Separating MB from milkdrop was possible before though that wasn't intended.
- Can't find the way to use milkdrop specific commands. Pleas allow to use some, if not all, frequently used commands, including preset selection list, display of the current preset name, and ability to run the previous or next preset or keep the current preset.
two small things:
- If Alt-D is assigned to this feature, maybe the key needs to be reserved?
- "Press F1 for help" message displays at the bottom when milkdrop starts.
