Author Topic: MusicBee for complete beginners  (Read 3691 times)
Pandarus
Hi folks,
Sorry to have to post this, but I can't find a musicbee for beginners tutorial anywhere and despite being told it's great, am about to head to Windows Media player instead.
I have actually been searching this wiki for hours to know how to do the following easily, with no luck:
I have a music collection on my hard disk that is bigger than the available capacity for storage on my Android Galaxy S2.
After importing my entire library to MB, I wish to sync a subset of these tracks to my phone. I want to be able to tell what's on my phone, and what's not, in list format (maybe a column?) in MB. And I want what is on my phone to show up on the left panel "device music" option when I click on it.
Though I have been able to test sync successfully thus far, I cannot see how to tell what is on my device. And when I select the device's left panel music option, nothing is displayed.
Please help! Please explain like you were talking to a child!
Thanks heaps!
Probably the easiest way is using highlighting feature (Preferences> Tags(2)> highlighting).
- Create a playlist of all tracks synced to your phone.
- Create a highlighting rule of "<playlist> <is> <the name of your playlist>"
- Add "highlighting" column to the main panel.
Then all tracks synced to your phone will have a highlight bar in the column.
Every device works different. If the device's music node shows nothing, what about storage folder? If you can't find it, post a screenshot of your device section with all nodes uncollapsed.
how to post a screenshot: http://getmusicbee.com/forum/index.php?topic=3998.0
