would you be willing to run a debug version?
if so, before i do that, could you remove a couple of the files from the library. Redo the scan and see if the removed files are still not added in.
Short answer is sure, I'd be happy to.
But when I just did this again, I discovered that MB is in fact finding the files, it's just not adding them to the library. They are being sent to Podcasts, under "Unknown Subscription." When I try to play it, it says it can't find the file, and asks me to browse for it. I cancel the browse dialog, and it starts playing the missing tracks.
These files are tagged with genre = "podcast". However I have a total of 59 files tagged that way and only 22 went to Podcasts, the rest went to the library. So I'm confused.
Yes, I'm willing to try a debug version, you'll just have to decide if it's worth it given the above information.
ron
Avoid infestation. Rotate.
