Author Topic: total mess  (Read 5073 times)
ron505
Got a new external harddisk. Didn't know what to do, so i copied all my mp3 to the new hard drive (another drive letter). now is MB finding double as much mp3 as i had on my normal drive. Removed the original MB and installed a new one. Search the new hard drive and the troubles started.
Can't play any music anymore, every mp3 is doubled on jy list.....help me
Try File> Rescan Files command with "remove dead links" and "re-scan files already in library" options ticked.
ron505
Did that but still double files and files MB says he can't find.
Is there a way to remove MB and all the related files so i can start all over again? Seems to me he still finds old settings after removing MB
Alumni
If you want to start from scratch make sure to delete this folder: "C:\Users\YourName\AppData\Roaming\MusicBee"
ron505
Thanks, i have managed the problems i guess. Still missing some files but i'll get over that. Now after installing the newest version the next problem.
When i send the files from the inbox to the normal music libtrary i get the message: move files....and after that i can;t find them anymore.  Even the directory where i put the original files is gone and i can't find them back....helpppppppp
Post a screenshot of your library preferences.
how to post screenshot: http://getmusicbee.com/forum/index.php?topic=3998.0
And describe the steps you took in detail.
ron505
Fixed it myself. Tnx for your help
