Author Topic: Hotkeys & JumpList  (Read 5365 times)
zzh1989829
1.seems "play library shuffled" doesn't has a hotkey binding setting ,i hope you can add this
2.add a little search bar in the preference dialog
3.add more win7 jumplist options ,such as start auto DJ,recent played song etc.
zzh1989829
btw,is it possible to add AERO feature in MB ,if so that would be awesome!
can you explain this some more?
zzh1989829
forget it,I have no idea either ,it just come out  from my mind ,to be honest, I don't have a clear concept of AERO.....
BUT , I find MB doesn't support Win7's some features when using a non-windows theme ,e.g. The snap
this site explains the snap: http://www.microsoft.com/windows/windows-7/features/snap.aspx
I think it is the last thing you want to do
Last Edit: May 17, 2010, 05:24:14 AM by zzh1989829
zord_majka
OK, from what I know this depends on MB skin you use. Some skin(s?) are "snap-able" and some are not.
its not supported when you skin the window borders (you have the option to use unskinned borders when selecting a skin in the View menu)
this is included in the next release on this forum
