Author Topic: MusicBee cannot view tracks by filename?  (Read 6745 times)
Muzeec
Some of my tracks show up with a blank name and artist. Do I have to tag each and every one of them or is there a way to view them by filenames?
Alumni
Right click on any column, go to other fields and you should see filename there.
You can also try the auto tag feature. Go to tools, tagging tools, auto-tag by tack, update tags from filenames.
Last Edit: February 15, 2014, 10:18:18 AM by Alumni
Muzeec
Sometimes I will try to use that auto tag feature but when I press preview it just says "no changes".
dylstew
Once on these forums I saw a comment by steven.
it said that there is a way to show the filename if the title is not there, but I don't remmeber how :(.
Are you changing the template to match your File naming system?
