Thanks, Steven. I did that along with copying the mb_VST.dll to \Plugins and the patch files to the main install directory and after start up I see the entry for selecting the VST directory in Edit->Preferences->Plugins. I made certain it points at C:\Program Files (x86)\Steinberg\VstPlugins which is what I use.
Where I am failing is trying to figure out how to then select, enable and configure a VST plugin. There is no Controls->VST and there isn't anything in Controls->DSP Effects that pertains to VST. If you can tell me how I should be doing that I'd greatly appreciate it.
