Author Topic: Saving embedded lyrics to file  (Read 2548 times)
vzell
Hi
It would be nice to have an option on the right click menu inside of embedded lyrics to save the lyrics into a file with the same name as the music file but with an extension of .txt or .lrc depending on the embedded lyrics type (or both if both are present).
It's already supported. Go to Edit> Preferences> Tags(1)> lyrics storage and tick "save as external file" option. Then you will get such a command upon right-clicking on lyrics panel, and MB will save it with either txt or lrc extension.
