Author Topic: Export playlist as text  (Read 6178 times)
smd
It would be cool to be able to export a playlist as a text (or similar) format list, including selected fields if possible.  That would be useful for times when you want to save a list of songs and your ratings of them (for example, to share with a friend, or to tell a friend what you think of a list of songs without having to go through each song).
you can achieve something like that already - just select the tracks, right click then Send To > Clipboard
after which you can paste like normal
To control the format of the copied track information, its in the Now Playing Preferences: 'send to clipboard format' setting
smd
Cool, I didn't know you could do that - but unfortunately "Rating" (and some other fields) are missing from the "send to clipboard format" setting.  :(
just type in <Rating> in the format - its not intentional that its missing from the field selector
smd
Cool, that works.  Thanks!
Is there a way to put special characters in there (like a "Tab" character)?
no - suggest for now you just use some character like | and then do a search and replace with a text editor
