Author Topic: Add "reset audio device" action/shortcut  (Read 2482 times)
ziflingus
Working with an external asio enabled audio interface, I am sometimes required to restart the audio interface, and make musicbee reconnect.
I do this by options->player->change output to "directsound"->apply->change output to "asio"-> apply.
It would be great if all this could be performed by a single keyboard action.
Thanks!
A keyboard shortcut to reset the audio device would be convenient, but not as convenient as fixing the problem that's causing the hardware to stall in the first place.
You might be better off posting this as a bug in the bugs forum, with any information you can think of that might help narrow down the cause.
