Author Topic: Podcasts  (Read 4744 times)
Diedrict
in mb 2.2 for selection shows all available podcast places
how to find selection in 2.3 directory ?
thank you
same place as before - right click on the podcasts panel/ Podcast Directory
or click the "+" button which is new
Diedrict
sorry, bring old 2.2 directory lists to mb 2.3...
2.2 :)
2.3 click on anything, is missing :(
thank you
Last Edit: December 16, 2013, 02:25:17 PM by Diedrict
I suggest you read through this thread to understand the history of the changes: http://getmusicbee.com/forum/index.php?topic=10710.0
Diedrict
very much thank you adding npr and dp podcast to mb
is possible to list itunes store podcasts same as npr and dp ?
is possible to search npr and dp same as itunes store ?
trim left space from dp podcast name to fix sort by ;)
characters display error on last items in dp music category list
Last Edit: December 18, 2013, 03:49:21 PM by Diedrict
i will include the ability to open the rss feed link in a web-browser as that is functionality that was effectively available before.
The searching functionality is restricted by the API's available from the podcast directory provider and the non-ascii chars are what is returned by the digital podcasts
Diedrict
thank you for explain API, i did think mb did search
hope is possible to list itunes same as npr still
how i set prodcast directory font same as podcast view ?
Diedrict
yes, and chars display well when subscribed, is a font issue in pre window? note last post screenshots
its as i said in my previous post.
