Author Topic: Can you make the icons in the browser the same size a the play list?  (Read 2048 times)
Iowaseven
Specifically when I have them set to display as large icons. It would make the interface a little more consistent. Thanks!
http://i.imgur.com/3Y61auE.jpg
the thumbnails in the now playing list are sized from the fonts and number of lines displayed for each file.
I have made the left panel more consistent for default settings and if you have 3 lines displayed, using large icons on the left panel should be closer in size but not perfect
http://musicbee.niblseed.com/V2_3/MusicBee_Exe_Patched.zip
