Hi
I made the mistake of buying some songs from Apple and now I would like to convert them so I can actually hear them. I DL'ed and installed BASS_AAC.DLL but now MusicBee says the files are corrupt or unplayable.
How does everyone else deal with this? Out of my 3-4,000 songs I only have a few like this. Should I just pitch them and give up?
There are TONS of audio converters out there. For example dBPoweramp is consider "standard" at sites like Redacted (audio filesharing site).
One benefit with that is that you can do batch jobs, for example a few hundred in each go.
There are a ton that can convert just about anything to anything else. Have you googled "Convert m4p to mp3"?
I have no personal experience since I never bought music from the Apple store. But I've converted lots of other copyrighted files to non-copyrighted.
Here is a forum with people who do a lot of conversions. I'm sure you can figure out how to do it.
https://forum.videohelp.com/When converting you ideally want to avoid loss in the quality of the sound... It's a bit of a science, but just make sure you check those settings and don't do any more than ONE conversion because the quality is reduced for every conversion you do.
