i did experiment with what you have suggested but i dont think i have enough time to make it work well. Perhaps i will revisit later in the v2.3 release
i made a tweak to the BackgroundAlbumCover to zoom in a bit less - could you confirm you are still happy with it. I think it works better with the tests i did
for the background image, i have created a new element<element type="BackgroundAlbumCover" brightness="0.2" refreshInterval="20"></element>its basically the same as what you have done except its more optimised and picks a random location on the album cover. It always sizes to the panel size. Also the refreshInterval (seconds) will choose a new random location
