Author Topic: DarkRED  (Read 185706 times)
S-Man
You have to change them manually. I'm using:
Main player:
Segoe UI Light 16pt
Compact Player:
Segoe UI Light 20pt (track)
Segoe UI Bold 10pt (artist)
Segoe UI Regular 9pt (album)
Mini Player:
Segoe UI Regular 11pt (track)
Segoe UI Regular 8pt (artist)
Ah, cheers!
One more question/request. I liked the way the progress bar options in Layout (2) worked in Red Flat. Any chance you could make the Metro version compatible with those settings? I like to use the "progress bar in middle" option since it makes the progress bar more compact. Would be great to have best of both worlds with the colours of Metro and the progress bar options from Flat. Of course, releasing the different colourways as Flat versions would be much easier.
silvestreccf
BTW, I'm working on a set of toolbar icons that match my skin.
Current set with alt versions:
https://dl.dropboxusercontent.com/u/10773406/Icons.zip
Any suggestions as to which icons shoud I do next?
Maybe a visualization button!!
endeavour1934
Updated all skins with changes on the Compact Player. Use the same links.
Kaelri
I'm a little late discovering it, but this is by far the most gorgeous MusicBee skin I've seen. If the author is willing, I think Steven should consider making it the default skin, or at least one of the pre-packaged options. It's very clean, modern, and makes a great first impression on people who've never seen MusicBee before and might even think desktop media players are a thing of the past.
On toolbar icons, there are two that I use a lot, although I might be the only one:
- Playback: Play Library Shuffled
- Playback: Stop After Current
If you were inclined to add icons for these actions, I (if no one else) would be grateful. :)
DroidZone
Hey there! I'd like to say great work on the skin, it is quite intuitive and very elegant! I just had one question.
How do you get your mini player to look like the screenshot below? I haven't been able to figure it out.
Thanks!
Updated all skin colors (including RED)
- New Miniplayer colors changed (view screenshot below)
- Love & Rating colors fixed
- A-Z jumpbar text color fixed on alternate color skins
You'll need the latest update because the mini player is still in development: http://musicbee.wikia.com/wiki/Latest_Update
You may also need to activate it in Preferences.
DroidZone
I see, thank you very much! It was exactly what I needed!
endeavour1934
Added sources for all versions on the first post.
carcafon
Thanks man!! Amazing theme, i just have one problem with it, can you make the auto-hide sidebars available?, for some reason when i use the theme the auto-hide option from the left and right sidebars is disabled, i mean, the sidebars don't show up when i hover the mouse arrow near them
Thanks!
endeavour1934
That's odd, they work perfectly on both of my computers. Maybe it's a problem with your preferences? Right click on the background of the left panel and make sure that "disable auto open" is not checked.
makaseo
Amazing skin, love it so much.
Any chance of a light grey or white version? Or is there a way I can edit the black/dark grey background colors myself somehow?
JMoss
My favourite skin, period.
The DarkCyan variant is just sweet  :)
silvestreccf
MiniLyrics Skim based on DarkRED (based on Metro) by silvestreccf with sourcefiles by endeavour1934.
MiniLyrics DarkED Skin
Link for this and others skin: http://www.artenix.com/search/label/TEMAS
Link direct: https://www.dropbox.com/sm/create/MiniLyrics%20DarkedFlat.rar
endeavour1934
All skins updated with the latest beta (5139) new features
Use links from the first post.
Last Edit: January 26, 2014, 06:21:49 PM by endeavour1934
silvestreccf
What change in this version?
