this is a debug version:
http://www.mediafire.com/?mjwvwymhznmjust unzip and overwrite the existing MusicBee.exe
but before you run it could you send me all the .dat files located in the musicbee data directory
- if you run MB as a portable application, they are located in the AppData where MB is installed
- otherwise if you run XP, they are located in something like: C:\Documents and Settings\<your id>\Application Data\MusicBee
- otherwise they are located in something like: C:\User\<your id>\AppData\Roaming\MusicBee
when you synch with this version it will write information to the error log (Help/Support/View Error Log).
If you could send me the results i can check it out.
I'll PM you my email address
