1. Go to Preferences> Layout (1)> Configure Fields2. Pick up a field you will most likely never use. My selection was "keywords" field.3. Rename the field to anything you like. I just made it blank.4. Add the field to main panel and position it at the beginning of column header.5. Now you can (1) sort by "group by" field by clicking on the column and (2) resize left margin of track list by adjusting the column.
You can use this trick for that as well.Quote from: redwing on April 18, 2013, 02:37:42 PM1. Go to Preferences> Layout (1)> Configure Fields2. Pick up a field you will most likely never use. My selection was "keywords" field.3. Rename the field to anything you like. I just made it blank.4. Add the field to main panel and position it at the beginning of column header.5. Now you can (1) sort by "group by" field by clicking on the column and (2) resize left margin of track list by adjusting the column.
Don't forget that you can use the Configure Fields pop-up from Layout (1) to change the alignment of any column.
It works perfectly except the " - " part, if it only has a disc title and no comment then it shows the ' - ' but it shouldn't.
change ...$IsNull(<Disc Title>,,<Disc Title>" - ")$IsNull(<Comment>,,<Comment>)to ...$IsNull(<Disc Title>,,<Disc Title>)$IsNull(<Comment>,," - "<Comment>)
$IsNull(<Disc Title>,,<Disc Title>)$IsNull(<Comment>,,$IsNull(<Disc Title>,," - ")<Comment>)
