And that's why I don't understand why people want to create playlists from MB to be able to read them with other software. Just use the playlist format that Steven developed.
There's lots of reasons to use plain-text playlists.
* If you change the location where your files are stored you can open a playlist in a text editor and do a search and replace to change "C:\MyOldMusicFolder" to "D:\MyNewMusicFolder".
* If files change often, leaving "gaps" in your playlists, you can use playlist checking programs (such as the previously mentioned ListFix) to more easily identify and correct missing tracks.
* Some people might want to create playlists in MusicBee but play them in a dedicated player program like AIMP.
...And MB just offers all you need.
...No need for other software.
Er... no. MusicBee just offers all
you need, but I don't understand how you can so readily dismiss the idea that other people might work differently.
* I can tag new files about ten times faster in Mp3tag than I can in MusicBee.
* I can find high quality artwork much faster in Firefox than I can in MusicBee.
* I can organise files faster and more precisely with a dual-pane file explorer than I can in MusicBee.
Sure, I
can do all of those things in MusicBee, but as long as it takes much longer I'll keep using those other programs as well.
