I want to remember the position of every separate track i play. After searching in this forum i saw a solution for this:
"if you dont use the audio-books node then the other alternative is to the set 'remember playback position' flag (using the tag editor/settings tab) for your audio-books"
But this only works after setting is separately for every single track. Also when new tracks are added it has to been done again for these new tracks.
Is it possible to make this a default setting somewhere, so that every newly added/played track will have this option set?
