Author Topic: Remember playback position' flag default  (Read 9546 times)
Dr_IT
I want to remember the position of every separate track i play. After searching in this forum i saw a solution for this:
"if you dont use the audio-books node then the other alternative is to the set 'remember playback position' flag (using the tag editor/settings tab) for your audio-books"
But this only works after setting is separately for every single track. Also when new tracks are added it has to been done again for these new tracks.
Is it possible to make this a default setting somewhere, so that every newly added/played track will have this option set?
Out of curiosity: Why?
It makes perfect sense for audio books and podcasts, but why would you want songs to start anywhere but at the beginning?
@Dr_IT, just in case you are not aware: there is a setting to resume position in the Player settings. Of course that only applies to the playing song when you exit MB and not to all songs.
Dr_IT
I listen to a lot of different tracks (mostly only once). Most of them are livesets which have a duration of more than an hour. So when i want to switch to another set (when i want a different genre) or on the next day, it would be nice to not have to start at the beginning of that track, but where i left off the last time i played it.
Dr_IT
Yes i am aware of this, but as you said that only works on current played track. If i start another the next day it is completely forgotten where i left off the last time on the played track(s)...
Even worse with this option if i double click on the last played song (which shows in progress bar the correctly last position), it starts from the beginning. So you have to press play, or everything will be lost and not a way to get back where you were last time...
Dr_IT
Can i conclude form the responses so far that at this moment there is no way for me to let this be the default setting?
So also not by adjusting a config file or plugin or something?
Does this then also mean it has to be developed in the main program? If so can i make a request for it somewhere?
Correct, correct, correct and yes, in the Wishlist forum.
But seeing as your initial question is already worded as a request, I'll just move this thread to make it easier.
Bush
I would like this too. Maybe an option to enable it per genre tag etc
Zeus
I'd also like an option to remember playback positions by default.
Half the podcasts I listen to don't use the "Podcast" genre tag, so if here was a way for MusicBee to resume everything regardless of ID3 tags, that'd be a big help. :)
simshaun
Hi. Sorry if it's bad form to resurrect an old thread like this, but this is what came up in Google when I was searching for this functionality.
I've written (an admittedly simple) plugin that handles this.
https://getmusicbee.com/forum/index.php?topic=27654.0
