Author Topic: How to run MusicBee on MacOSX  (Read 32849 times)
canonlp
Here is how you can run MusicBee on MacOSX without using parallels to virtualize a whole OS to just run 1 program. Using Crossover, you can install MusicBee and run it like a normal application. Here is what you would need:
1. Crossover 12.5.0
2. Portable MusicBee 2.1
3. MacOSX 10.8.3
*Note: It may work for other versions as well. I have only tested on my own machine.
1. Install Crossover
2. Download and extract the portable MusicBee
3. Run the extracted .exe and a window will pop up, click proceed.
4. Install MusicBee
5. Once it is installed, in crossover go to Programs -> Run Command
6. Using the MusicBee bottle, browse to where the MusicBee application is installed, which for default should be located in "users->crossover->desktop->MusicBee->MusicBee.exe"
7. To make your life easier, press "save command to programs menu"
8. Click run (disregard the error that pops up)
9. Enjoy  :D
Here is a picture of it running on my mac.
Wonderful! Thanks for the tip.
Two questions:
How does MB work on that environment as compared with PC? Fast enough? Any limitations or shortcomings?
What was the error message popped up?
canonlp
So far in my testing, it has been pretty stable and fast. There are some graphical issues (the color seems to be off) but its nothing a skin wouldn't fix. I have only tested a few functionality and they seem to be working fine.
The error that came up was for the .net framework. I'm not sure what it meant, but all seems to be fine.
Thanks for the replies. Sounds good. I'd appreciate if you keep it updated for current and future Mac users.
ma_t14
I will leave the thread here for now to give it the exposure it deserves but will move it to the How To section eventually
I've added this to the FAQ page on the wiki, in addition to the other guide.
drpepo
Hi canonlp,
This looks like a great way to have the Bee fly on a Mac. Any additional news or insights after your last post? Do you still use it?
Thanks a lot in advance for a quick update.
Best
Peter
Dingusamongus
I've tried doing this.  I can get Musicbee to run, but it lacks the functionality that really makes Musicbee sing on Windows.  The tagging can be done by editing it yourself, but you can't use the great added plug-in tagging look-up features within Musicbee.  You also can't transcode or convert files from a flac to a mp3 or etc..  If I could get it to do those things it would be AMAZING, but alas.  The only other thing would be to export to an Itunes playlist so you could then load it onto an ipod or something.  So, I just have to find other solutions like the crappy manager which is slow and bloated Itunes, that won't even recognize or play flac files.  If anyone finds other solutions, please post them.  I'm waiting with bated breath.
Cheers,
D
haywooj
Actually, using the latest version of CrossOver, you don't need to do anything other than to "Install new application", and type MusicBee.
The app will install all for you, including necessary .NET and an SDK
Job Done!
jaume
Just a note that MusicBee 3.0 does not work with Crossover as MB does not support XP anymore.
I managed to install MB 2.5. However, MB dies not see the Mac folders and drives. How can I make it see these so it can scan the music library?
there are other ways to run MB on a mac now. See the most recent entry in the tips and tricks section
