Author Topic: AlbumArt.lnminente  (Read 10048 times)
lnminente
Inspired by the Album Art released today by Redwing http://getmusicbee.com/forum/index.php?topic=10431.0 i wrote this another one:
The innovative thing here is the seekbar, while you see a very thin line, all the bottom bar is clickable for seeking.
Download: http://www.mediafire.com/download/275o1uv6duyq8sq/Album_Art.lnminente.zip
Edit: Updated, gave 5% of transparency to the grey box over the hidden seekbar for giving a very sutile clue of what it makes.
Last Edit: August 10, 2013, 12:12:55 AM by lnminente
lnminente
Updated again: Now cover is clickable and acts playing/pausing like a youtube video
Great! I like your simple and useful improvement  :)
tromaster
  • Sharing is caring!
Thanks a bunch, was just looking for something like this: just album art and minimal info (couldn't care less about artist pics  :D).
Thanks again, will give it a spin right now.
tromaster
Having a little problem: The artist name doesn't show, just the hyphen and track title. The tags are ok, when I change to a different view (e.g. the default one) the artist name does show up. The only change I made is to increase the size of the display from 300 to 400 (line 4 in the XML). Am I missing something?
Cheers.
Roadrunner
Same here, without changing anything. I suppose on line 36 there's the following part missing:
<child id="Artist"></child>
lnminente
I fixed that but had some mistake when updating the file. Thanks for reporting it guys, link updated (Y)
@tromaster: Same here, the truth is it was very easy and i'm very happy with the result. I use it for pausing a song, listen something on the web, and later follow playing easily :)
BTW I miss a setting for setting the TM "Always on top while playing". Scrolling the "Artist - Title" when is not fully visible would be great too.
Last Edit: August 10, 2013, 12:27:45 AM by lnminente
tromaster
Works ok now, thanks for the quick fix  ;D.
Cheers, y saludos de Chile.
