Author Topic: Dark Matter  (Read 22166 times)
Iasc
I am using the Dark Matter skin and find it almost impossible to see the scroll cursor in the main window. This is even after adjusting the brightness on my laptop screen. Is there any way of changing the cursor color or shading? The cursor is supposed to be visible directly below the triangle in the image below.
Any help is appreciated.
I have made a change to the skin. Please redownload.
Cliff
Thank you for modifying the skin. I downloaded it and I see no difference. See the enlarged image below just to the right of the "Path" field in the main window.
Cliff
Well, that is weird. I have tried this on a desktop and a laptop with the same results. Are there any other MusicBee settings that could affect the shading of the cursor?
