Author Topic: MusicBee behavior when creating a new playlist  (Read 3270 times)
Pako
I would like to unify MusicBee behavior when creating a new playlist.
Current Status:
A) New Playlist
1) I can edit the name of the new playlist
2) That's all. No dialog opens.
B) New Auto-Playlist and new Playlist Mixer
1) Opens a dialog where I can to configure
2) That's all. I have to manually select the "Rename" of playlist
I think that the logical and correct behavior would be as follows (in all cases):
2) Opens a dialog where I can to configure
Pako
Pako
I am returning to this old topic.
Now (version 3.1) the status is changed:
A) Ordinary playlist
Behavior is the same as described earlier. Once I choose a new playlist name, the dialog closes. I have to mark a new item in the playlist list and manually choose to edit it.
2) Auto Playlist
In this case, the program behaves as expected.
Pako
i think it would be benefitial that the playlist setting dialog opens when a new playlist is created, so for the next update when a user creates a new static playlist, the settings dialog opens and now includes the playlist naming in that dialog.
The naming is also included in the auto-playlist dialog, and i will also do so for radio playlists
Thanks for this.
... and i will also do so for radio playlists
Nice, thanks!!  Appreciate you including Radio enhancements in general MusicBee development
Pako
... for the next update when a user creates a new static playlist, the settings dialog opens and now includes the playlist naming in that dialog.
Thanks !!!
Pako
