Hello, Steve,
I don’t know if this is exactly a wishlist item, but you suggested opening a thread, and so I am doing.
I’d like to propose to disconnect (if this is the right word) two features: displaying Details, Artwork and Lyrics in tabs on the right sidebar, on the one hand, and displaying the Now Playing list on the aforementioned right sidebar, on the other hand.
The consequences of this connection, of these two features being linked, is that, when you are on the Now Playing Playlist, there’s no way of having Details, Artwork and Lyrics displayed in tabs, since the Now Playing list can’t be turned on.
If you go, on the right sidebar, to Customize panel settings, you’ll see that, as I’ve just said, the Now Playing list can’t be turned on and that prevents the user from selecting the layout in tabs for Details, Artwork and Lyrics, which is the best layout in my opinion.
Here are two captions you may find useful:
https://dl.dropboxusercontent.com/u/17615125/Capture_1.pnghttps://dl.dropboxusercontent.com/u/17615125/Capture_2.pngI hope I explained myself well.
Thanks,
David
