Author Topic: Column Width  (Read 887 times)
Mac
Hi All,
In the menu location -  View/Arrange Panels/Main Panel/Files/Panel Settings/Artwork it is possible to alter the column width of the displayed tracks ??
Yes -- I do know you can have a single column list but this is too narrow and chops off the end of some longer track titles.
Hi, welcome to the forum!
I think a screenshot would be helpful so we can see the context. Thanks!
I'm not 100% sure which view you're referring to, but the answer will be no.
If the track list doesn't display column headings, you can't adjust the widths.
The only exception is the track list in the Compact View, where the column widths can be set in the layout settings for that view only.
Tybot
I'm gonna assume Zak understood you correctly. You could change the font and/or the font size, but it's really difficult to accomplish what you're asking. Sooner or later you will run into tracks with titles that are still too long.
