Author Topic: LyricsReloaded  (Read 242178 times)
Do you not get notifications from this thread?  It was stated that the links weren't working, and two months passed without any response from you.  I expect whoever did it assumed that you would have seen the posts yourself.
quick_wango
  • Software Engineer
I scrolled through the posts yesterday, but didn't see anyone stating that the link has been replaced at first glance. I guess those notification mails must have been dropped by getmusicbee.com's Mailserver during the short downtime of my Mailserver. Someone should check those deferring settings, none of my other mails got lost.
@whoever changed the links: Why the hell have I not been notified about the links not working? Instead the links where replaced by a random mediafire link without me knowing about it. That is definitly not the way this should be done. I'm kinda disappointed with the moderation.
I don't really get your point. Is this your way of say thanks to people who took care of your plugin on behalf of you during your absence? It's not just "a random mediafire link" but a temporary link I hosted that the moderator who edited the first post must have confirmed it's the same file that you had released.
One odd thing is I remember I saw you logged in right after I posted the temporary link post about two months ago. I thought you would take some action but you didn't. And all of sudden you are blaming people for working on behalf of you and the "lost" notification you must have received without taking any action during that period.
quick_wango
  • Software Engineer
That was totally not pointed at you. Thanks to you for hosting it.
But we're dealing with DLL files here that could potentially do anything to a users system.
The first time I logged in (and actually looked into the forum) after the server migration was when I posted that I found out that the download was down (I tried to download the plugin myself). I might have been online before, but that was probably while migrating my password database. If it was on that day, it was probably by coincidence.
Mails getting lost is something that can happen during a server migration and 1-2 days of downtime, but most servers have their deferring configured with long enough delays to be able to hold mails for several days. Checking the deferring settings was a suggestion, not an attack.
Anyway the download is up, I might switch the site to https eventually in the coming days or weeks. I also might have time to work on the plugin again which will likely result in implementing another pile of providers and maybe some other goodies.
OK, I guess that clarifies it.
Keep up the good work! Your plugin is quite popular - more than 400 downloads just for two months.
quick_wango
  • Software Engineer
As a final response to download being offline:
I switched the distribution to GitHub's releases which are much more reliable for you.
The main post has been updated to link to the latest release on GitHub which provides download links for the binary (mb_LyricsReloaded.dll) as well as source downloads.
quick_wango
  • Software Engineer
And here we go: Version 1.1.2.0 released.
This is a bug fix release:
* removed providers that are offline
* fixed lyricwiki and az lyrics
* fixed the update checker (there won't be a notification for this update sadly)
Download: https://github.com/pschichtel/LyricsReloaded/releases/tag/1.1.2.0
I also moved the provider to-do list into an issue: https://github.com/pschichtel/LyricsReloaded/issues/11
New providers can either be posted in that issue or here as usual.
Other issues have been reorganized as well
cubedparadox
Cool plugin, I'd love to see support for musixmatch.com 's api, they have a ton of synced lyrics, as well as standard lyrics for many more songs. I have synced quite a few of those myself, and I'd like to be able to use them in my favorite music player. :)
Thanks, and keep up the great work!
Sergio
Gracias, saludos desde Chile !!!
Thanks, greetings from Chile !!!
ResoOner
Hey man loving the plugin, however RapGenius is no longer RapGenius, it's now known as *.Genius.com (* being Rap, Rock, Lit etc) a simple tweak to the file "LyricsReloaded\Configs\rapgenius.com.yml" fixes it.
If anyone would like, I can post the modified DLL here (along with a VirusTotal report, of course)
Please do!
Hiona
Doesn't work here.
I copied the mb_LyricsReloaded.dll in this folder C:\Program Files (x86)\MusicBee\Plugins.
The plugin is listed in the plugin section but nothing happens when i click on the configure button.
Does anyone else do have this problem or did i done something wrong?
Here is the log file: http://pastebin.com/066kSHKA
Sorry for my bad english
quick_wango
  • Software Engineer
Can you make a Pull Request over at https://github.com/pschichtel/LyricsReloaded so I can add it to the official build?
Also providing a patched DLL is a) not necessary as the *.yml can be placed in the plugin folder and b) is not really wanted because DLLs can be harmful.
Doesn't work here.
The plugin doesn't provide any functionality on the configure-button, that's expected. The log also doesn't show any problems except the update check not working (again... Github, fix your SSL!)
Last Edit: October 22, 2014, 12:55:39 AM by quick_wango
herpdorpinkins
is it possible to have some more sites added? the vast majority of my music is heavy metal and most of the default sites cant find anything for me :(
quick_wango
  • Software Engineer
You might look at and comment this issue: https://github.com/pschichtel/LyricsReloaded/issues/11
Or if you know regular expressions you might add support yourself.
For this you can look at the documentation at GitHub and in the Wiki
