No problem. Functionality of lyrics fetcher is just the same regardless of installing those plugins.
Instead of using "Update Missing Lyrics" command, you can also add lyrics using right-click menu of lyrics panel. With this, you can redo lyrics search using multiple providers until you find the right one.
