Author Topic: Mellon Remix  (Read 32374 times)
First post updated.  Major overhaul, but link is still the same.
Updated with lowlight scrollbars.
Minor updates
did you upload your updates? the fle is no different from the last i retrieved
I thought I did, but I'll try again when I get home.  It'll be a few hours.
Try it now.  I put it in the folder, but for some reason Box Sync had been turned off.
yes its different now. However it might not get included in the final release package depending on whether any serious bugs get reported in the next couple of days
Not sure what you mean by that, but okay.  :)
