Author Topic: Mellon Remix  (Read 32246 times)
Thanks!
Updated to 2.2.5027 (search node icon)
mrad
All I can say is tasty ;)
just a qu: How did you get the "Details", "Lyrics" buttons to appear above the right hand side [ "Playing track" ] header ? If I select "customise" via right click on the "Track Information" (which I have where you have those buttons) and enable Lyrics, I cannot see them.
Last Edit: October 06, 2013, 02:56:08 PM by mrad
It's hard to know without a close look at your settings, but this might help you figure it out: http://musicbee.wikia.com/wiki/Right_Sidebar
mrad
Ah nice, yeah that helped, actually there is a slight bug in there, either way, I have the buttons back now :)
Thank you.
Last Edit: October 06, 2013, 03:49:55 PM by mrad
Major update with new elements: Modern Mini Player, Now Playing List & Column Browser, miscellaneous minor adjustments.  Changed Compact Player colors to match the mini player and the main player panel.
Let me know if I overlooked anything that needs to be adjusted.
ttapu
Big thank for the skin. Its not only nice and thorough but the file is very well organized so it was easy to make some modifications for myself. I made an eye friendly subversion  ::)
https://www.dropbox.com/s/ynicja8983o370g/MR2.jpg
Great!  Glad you were able to make it work for you.  :)
Revised original skin to use rounded window borders and scrollbar arrows.
Added a preliminary Modern version which uses square window borders and no scrollbar arrows (and new layout).
Let me know if anything in the new skin looks wrong.  It's primarily intended for tabs in caption bar.
Last Edit: July 03, 2014, 02:14:54 AM by scampbll
Update to modern skin.  Restored original top border color, a few minor tweaks.
Updated scrollbars in both skins, squared tabs in the modern version, plus a few minor tweaks to make them match better.  Links are the same.
Edit: Whoops, overlooked the column browser.  Fixed now.
Last Edit: January 07, 2015, 06:10:04 AM by psychoadept
Thanks to phred for pointing out that the wavebar elements in the flat player were missing.  That's fixed now.
AravindM_Vito
Great Skin Buddy !!  8) I'm not fan of bright colors  :P ...
Thank you, I think.  :)
