Zokay, I'm stumped again. How do I fill in the line between the "LibraryExplorer" header and the bar showing the categories?
Also, is it possible to skin that bar separately from the Playing Track panel, or are they always linked?
There are two lines, these determine them:
<element id="Panel.Body.Default" bg="255,0,0" fg="15,15,0" bdr="216,216,216" />
<element id="Panel.TabSelector.Default" bg="0,255,0" fg="75,75,75" bdr="0,0,255" />
As you can see used 1x red, 1x blue, 1x green for this example. This shows there is quite some 'sharing' going on:
