Author Topic: Metro Skins  (Read 125316 times)
Thanks for sharing your great work! They look very clean.
It seems still there's something to need to sort out. No problem running your skin now, but every time exiting from your skin, "MusicBee has stopped working" dialog pops up (no error log though). Would you have a look at the issue?
  • MB Version: 3.6.8849 P
Looks good. Nice work on the icons.
A few things you might want to look at:
You may have made your icons bigger than 16x16, so you get a little cropping in the address bar
There is also very little difference between disabled and active states in the navigation buttons
when the player bar spectro is on, the track times are partially overlaid
when using the floating edit screen, the white-on-white can be a bit (IMHO) hard on the eyes
maybe a 1 pixel light grey edge?
It's also very hard to see the ratings stars in the main panel
Looking forward to seeing your dark version  :)
V4lve
I love this.  Woudl be good to have a subtle border around the whole window for when MusicBee is not maximised.
JMoss
Thanks, your post is extremely helpful ;)
First problem: I corrected the icon size (from 18x18 to 16x16) but I'm still getting a little crop in the address bar. How could I solve this?
(In the screenshots there's no cropping, due to the fact that I run MB on a 1080p screen with 125% of dpi magnification)
if you post the updated version i can see if it displays correctly on a 96dpi resolution
JMoss
Done, the skins have been updated ;)
Thank you!
the bitmap image has a resolution of 71.98 - it needs to be saved as 96dpi
lnminente
@JMoss: In case you are experiencing problems with your image editor, try saving the images with Paint.NET for better compatibility
JMoss
Thank you for the tips, dudes.
@redwing: I'm sorry but I have absolutely no problem running both skins on MB, even on different versions of Windows...
I've tried them on v2.0 and 2.1 beta, no issues.
Yes, I don't know what's changed, but I can confirm the error dialog no longer pops up with MB 2.1.4841.
03/04: Fixed overlapping spectrum in player (to test)
working fine in Charcoal, but not in Blue
03/04: Added 1px border to the edit panel to improve visibility
I love this.  Would be good to have a subtle border around the whole window for when MusicBee is not maximised.
wasn't quite what I envisaged, but it looks good  :)
JMoss
Argh, I forgot to update the offset value in blue xD
That's a temporary fix ;)
I'm planning to fix borders here and there.
derausgewanderte
I like the skin. Thank you for your work. For me the "edge" around the buttons, lines in general are a little too thick. I think this would look nicer if they were more delicate, thinner. Looking forward to updates.
thank you again for a nice skin that I like next to Calcium.
Alexis
Nice work....The download link for these are not working at the moment.
