Author Topic: Add Right click menu tagging options to the now playing list  (Read 13297 times)
toology
... because of people who tag first and then add to the library.  :) Thanks!
that should already be there, right-click and choose Edit
another feature that might be useful for this is if you download tracks from the web, you can set the download target to the Inbox so all the pre-tagged files are in a 'holding' area before you tag them properly and then drag them to the library
toology
Oh okay, I didn't notice that edit worked for multiple files. Thanks for the tips!
