Author Topic: Social Networks Status Plugin  (Read 66007 times)
Its because of massive status updating in the past. As far as I understood from facebook developer page you should wait with using plugin for an approximately hour:
https://developers.facebook.com/docs/reference/ads-api/api-rate-limiting/
  • New plugin version correctly parses singe-key hotkeys in textboxes, i.e. you can assign for example 'space' as hotkey and use 'space' as normal character in plugin settings window
http://www.mediafire.com/download/pwhs78e64zr7zfh/mb_SocialNetworksStatus_2014-04-14.zip
You need MB 2.4 latest patch to use new plugin version:
http://musicbee.niblseed.com/V2_4/MusicBee_Exe_Patched.zip
Triopticon
I was wondering if it is possible to include an image file when it posts?  Such as the album cover image in the MP3?
Triopticon
Thanks.
I am getting this error when it tries to update my Facebook
(OAuthException - #190) Error validating access token: Session has expired on May 17, 2014 7:00am. The current time is May 17, 2014 9:56am.
It posted fine this morning.  I have it post once every 20 songs which is always over an hour.  Even if I try to update status manually it gives me the error.
However, it posts fine to Twitter.
Any suggestions?
Try to log off (in plugin preferences) and log on again.
Triopticon
OK, that seemed to work.  I will see what happens after an hour +.
Thanks!
Triopticon
No, it failed, again
(OAuthException - #190) Error validating access token: Session has expired on May 17, 2014 12:00pm. The current time is May 17, 2014 12:28pm.
Current Time is 3 hours behind my time.
Yes, I can reproduce this. It happens when status updates have interval more than hour. I'll try to ping server to avoid this. Maybe tomorrow, but don't promise.
wmaxlees
So I was messing around with the code a bit since you had it posted up. I changed the way that listening data is posted to Facebook if you wanna check it out. It uses Facebook Actions instead of just using a me/feed/ post so that it appears more like Spotify where Facebook sorta gathers the info and then posts a bunch of the songs all in one post automatically.
I'm not sure where to put the code if you wanna see it. I don't wanna put it on my Google git account because you have to license the code which mostly isn't mine.  ;)
Zip and upload your code to mediafire (or any other file sharing service) and post the link here. Maybe I could enhance the plugin by adding some options.
Also it doesn't matter that initial code is not yours - feel free to fork the plugin if you want (under any license you want).
wmaxlees
I put it up on my Google Drive. You should be able to get the code here: https://drive.google.com/file/d/0B51M5KSRCcLfc1h5OXc3ZzVzOWs/edit?usp=sharing
I added an UpdateAction() method to the Facebook object that is called when the plugin gets a PlayCountChanged event call. I also had to change the Facebook app that the plugin was connected to so that I could implement the Action via Facebook. It's not that hard to figure out I don't think, though. https://developers.facebook.com/docs/opengraph/using-actions/v2.0 for some info on Actions.
