Author Topic: Social Networks Status Plugin  (Read 66025 times)
Plugin updates your status in social networks according to the music you are listening.
Supported social networks
  • Facebook
  • Twitter
  • VKontakte
Full description and download link
Provide feedback on this topic
Last Edit: August 15, 2022, 04:46:45 PM by boroda
this is really good news boroda74 as its been asked for quite a few times
Iasc
thanks very much boroda74, im sure a lot of people will use this.
Iasc
hate to be the bearer of bad news but i keep getting this error in music bee  after configuring the plugin. i edited the tags and separator text to- My Name is listening to: Tag 1= Artist, Separator Text= -, Tag 2= Title, Sepertaor Text= with Music Bee. Tag 3 & 4 not used.
MusicBee v2.1.4802.15719 (Win6.2), 28 Feb 2013 15:49:
System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.InvalidOperationException: There was an error generating the XML document. ---> System.InvalidOperationException: Instance validation error: '-2' is not a valid value for MusicBeePlugin.Plugin.MetaDataType.
   at Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationWriterSavedSettingsType.Write1_MetaDataType(MetaDataType v)
   at Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationWriterSavedSettingsType.Write3_SavedSettingsType(String n, String ns, SavedSettingsType o, Boolean needType)
   at Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationWriterSavedSettingsType.Write4_SavedSettingsType(Object o)
   at System.Xml.Serialization.XmlSerializer.Serialize(XmlWriter xmlWriter, Object o, XmlSerializerNamespaces namespaces, String encodingStyle, String id)
   at System.Xml.Serialization.XmlSerializer.Serialize(TextWriter textWriter, Object o, XmlSerializerNamespaces namespaces)
   at System.Xml.Serialization.XmlSerializer.Serialize(TextWriter textWriter, Object o)
   at MusicBeePlugin.Plugin.SaveSettings() in c:\Users\????\Documents\Visual Studio 2012\Projects\SocialNetworkStatus\fb-csharp-sdk-winforms\SocialNetworksStatus.cs:line 735
   at MusicBeePlugin.Plugin.Configure(IntPtr panelHandle) in c:\Users\????\Documents\Visual Studio 2012\Projects\SocialNetworkStatus\fb-csharp-sdk-winforms\SocialNetworksStatus.cs:line 720
   at #=q2E4F0Yn4M3Nb9zZCz9OeVk_C10Vg45xqzfgNTSgILrc=.#=q89J63e5lgOHzF5VF0TbYHQ==(IntPtr #=qtCJok6VsEbR101ZyzyD$NQ==)
Last Edit: February 28, 2013, 09:38:55 AM by iasc
Iasc
even though the error appears after configuring the plugin it still posts the status successfully on facebook so not an issue. thanks again
Suggest that your settings are nor saved between MB sessions. :) I know the cause of this error and I'll fix it.
Its fixed. Redownload plugin from the 1st post.
Iasc
 that was fast, thanks.
yakamoneye
it does not work for me  and statut apdate is :
MusicBee v2.1.4770.37287 (Win6.2), 4 mars 2013 21:24:
System.IO.FileNotFoundException: Impossible de charger le fichier ou l'assembly 'Facebook, Version=6.0.10.0, Culture=neutral, PublicKeyToken=58cb4f2111d1e6de' ou une de ses dépendances. Le fichier spécifié est introuvable.
Nom de fichier : 'Facebook, Version=6.0.10.0, Culture=neutral, PublicKeyToken=58cb4f2111d1e6de'
   à MusicBeePlugin.FacebookService.updateStatus(String status)
   à MusicBeePlugin.Plugin.updateStatusEventHandler(Object sender, EventArgs e)
   à #=qfEcvfSplUAA8C$m77Ib8k2gIWCOcwCGMCGemgEATbVcVZdaCdJktIymCIIlDlxcu.#=qk2rzQxwf3DLpet5RcYYu3w==(Object #=q7wczJ394HxYvRK5YDXSq$g==, EventArgs #=q5VQImdh3PGf2r8X_CEOeAQ==)
   à System.Windows.Forms.ToolStripItem.RaiseEvent(Object key, EventArgs e)
   à System.Windows.Forms.ToolStripMenuItem.OnClick(EventArgs e)
   à System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e)
   à System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)
   à System.Windows.Forms.ToolStripItem.FireEventInteractive(EventArgs e, ToolStripItemEventType met)
   à System.Windows.Forms.ToolStripItem.FireEvent(EventArgs e, ToolStripItemEventType met)
   à System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)
   à System.Windows.Forms.ToolStripDropDown.OnMouseUp(MouseEventArgs mea)
   à System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
   à System.Windows.Forms.Control.WndProc(Message& m)
   à System.Windows.Forms.ScrollableControl.WndProc(Message& m)
   à System.Windows.Forms.ToolStrip.WndProc(Message& m)
   à System.Windows.Forms.ToolStripDropDown.WndProc(Message& m)
   à System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   à System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   à System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
AVT : la journalisation de liaison d'assembly est désactivée.
Pour activer la journalisation des échecs de liaison d'assembly, attribuez la valeur 1 à la valeur de Registre [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD).
Remarque : une certaine perte de performance est associée à l'enregistrement dans le journal des échecs de liaison d'assembly.
Pour désactiver cette fonctionnalité, supprimez la valeur de Registre [HKLM\Software\Microsoft\Fusion!EnableLog].
when MB start ( i start FB before ) i have 2 windows , the  first :  some tag names are dupliucated.Plugins is not properly initialized  when i press ok the second window open .
in french  impossible de charger le fichier ou l'assembly  facebook, version =6.0.10.0, culture=neutral, publicKeyToken=58cb4f..... ou une de ses dépendances.Le fichiers spécifié est introuvable.
please can you help me , i thank you to do this plugin for us
excuse for my poor english level
yakamoneye
Last Edit: March 05, 2013, 02:37:44 AM by yakamoneye
@yakamoneye
Sorry, I forgot to include 'Facebook.dll' in plugin package. Redownload plugin from the first post.
yakamoneye
thank you  boroda74  for your work. I installed the new plugin.
I still have the same first window.
But then I have no problem setting a FB window opens asking me my password, I filled all, but I do not always appear that I listen to on FB or my friends.
@yakamoneye
Do you mean that status update sometimes is successful and sometimes is not? I'm afraid I cant help with this.
yakamoneye
For me , never. Sorry perhaps i do something wrong. But Any my  friends and me never see my status with « je suis entrain d'ecouter    x group, x album x title »
  yakamoneye
Is any error message displayed when click 'Update status' menu item? Is some text in statusbar displayed during status update?
