Author Topic: Highlighting rules sharing  (Read 48152 times)
Gary Young
I use the highlighting rules rather for shading specific tracks.
Just like greyed-out tracks (dead links) look like.
As mentioned here (http://getmusicbee.com/forum/index.php?topic=7781.0) this way I visualise tracks which I own on CD but which are not ripped to harddisk. So to say: "offline tracks".
EDIT: I forgot to mention what was intended by the initial post - the rule itself. It's pretty simple:
Color all ASX-files grey (.Ext is 'asx')
Last Edit: February 22, 2013, 10:52:44 PM by Gary Young
Deping
Well, I mean, it doesn't really take any time.
  • MB Version: 3.6.8878 P
Now Touring
placed in #1 position
Touring?  |  is  | 'Y'  with SongKick icon (download here)
will temporarily override other highlights with when artist is touring
nepanitukka
hi there,
maybe noob question:
where and how can I set up those rules?
I´d really like to change duophonic skin´s highlighting color
and the thingy with the small speaker icon is also very annoying for me
so here I see the solution in front of my eyes and don´t know how to implement it.
Any help?
Highlighting rules can be set under Preferences> Tags (2).
But it won't address any of your issues. You'd better talk to the skinner as that skin is un-editable.
nepanitukka
un-editable as in "highlighting rules" do not work in this template?
(tried to highlight all - bitrate - smaller than - 192k  and it did not work)
Highlighting works for any skins (Maybe you didn't tick text option or didn't add highlight column to the main panel).
But both of your issues (highlight bar and speaker icon) can be addressed only by editing the skin.
nepanitukka
thanks a lot!
adding the highlight cloumn helps a lot ;-)
Rule:
All | title | is | actual title
gives me a nice green square - can live without the highlighted bar for the moment
greetz
hf
Mathiross
Hi everyone,
In the INBOX view, I 'm searching how to highlight with a "!" icon each time it's not ready to by automatically sorted and I would like to highlight the files when the folder contain tracks with many artist.
How would you do that?
thanks a lot !
didn't understand this, maybe my english is too poor
do you mean folder of file system? install additional tagging tools plugin, open auto library reports, create new preset, add 'grouping (Path)', add function 'count(URL)', assign some virtual tag function id to preset, update it (save it).
create highlighting rule: virtual function id | is greater | 1000
or some other number instead of 1000
plugin:
http://www.mediafire.com/file/g7bpm0djxh4c06g/mb_TagTools_2018-03-15.zip
Last Edit: March 15, 2018, 08:43:31 PM by boroda74
karbock
Three icon positions, always in the same order:
  • Is the piece instrumental, sung with accompaniment, sung a cappella or spoken?
  • Language flag (or empty if instrumental)
  • Lyrics available?
Last Edit: April 23, 2023, 07:31:12 AM by karbock
